Brake Sound ur quickly
Lars1998
Beitrag von Lars1998 »
Hey When I am Braking in my 54 quickly, there is a clack sound at first when using the pedals, it is only one clack and the brakes work normally! What could this sound do? New springs and new brakes installed in the rear wheel? Could it be the little round thing in the brake plate that goes into the frame that has too much play because of wear on the rear end?🙂 Hope it makes sense, will send a picture of the little round thing I'm talking about🙂 -Lars
Knigge
Re: Brake Sound ur quickly
Beitrag von Knigge »
Ich habe dieses Knacken beim Rücktritt tatsächlich auch, aber nur bei der 1955er. Ich vermute, es ist die Welle auf der Pedalachse im Getriebe, denn es knackt, das Pedal gibt ein wenig nach, und erst dann greift die Bremse
Lars1998
No not in the gearbox here, the sound is definitely from the rear wheel, anyone else who have had problems with the pin on the brake plate that goes into the frame?
Think the Brake plate maybe has too much Play in the frame and therefore twist a little when applying the Brake!
know it is not from my transmission Axle on the pedals since I made the engine myself and did everything according to the manual :)
Hope for some answers from other with the same problem!
Lars1998
Is there anyone else that know anything about it?
Lars1998
anyone??? I need som advice and help....
Audimax55
Beitrag von Audimax55 »
Hello Lars,
I have the Same Klack Sound and i am surching since a couple of day for the reason. Sorry for my english! Tomorrow i will try to minimaize the gab between the pin and the Frame. I think this is a good idea. I will let you now the result.
Rainer
Lars1998
Sounds good, maybe it could also be the nut that holds the brake plate that need to be tightened and the axel nut also, I will try that!
How are you planning to minimize the gap?
-Lars
Audimax55
Just to find the source of Noise i will fix temporär a shrinksleeve. Also i will disconnect the rod from gearbox to the brake. Then i can be shure the Noise is comming von gearbox or rear weel. It will take time, i am a old man.
Lars1998
sounds good, looking forward to hear what it was? I think my sound came from a loose nut on the braking plate hopefully it is fixed after I tightened it.
Audimax55
Hi Lars,
Today i removed the rear wheel and i put a heatshrinking sleev on the 10mm pin, which is holding the brake in the frame.
After this there is no „Klack“ sound anymore. It means, my problem is solved. hope it will solve your‘s too. Good luck.
Lars1998
So the problem was the pin in frame?
Did you Also tigten the nut that holds the Brake plate? My problem was gone after I tigtened the nut on the Brake plate
Audimax55
The nut at my brackeplate was already tight. In my case the gap between pin and hole in the frame was the reason for the Noise. Have a nice weekend.
Lars1998
thank you for the input. I will report back once I have taken a look on my own and found out what the problem is caused by :)
Lars1998
Es befand sich wahrscheinlich im Rahmeninneren in dem Langloch, wo der Stift des Bremsbelags hineingeht, und hatte eine Unschärfe. Ein Glied der Kette bewegte außerdem den kleinen Stift weiter nach vorne im Loch/Schlitz, wo er keine Lücke mehr hat und das Geräusch beim Bremsen nun weg ist.
Sie könnten das kleine Loch wahrscheinlich an die Innenseite des Rahmens schweißen, aber es geht um Mm und ich habe nicht die Fähigkeiten dafür, also war ein Glied in der Kette die Lösung des Problems :)
