Vergasser Nadel
Lars1998
Vergasser Nadel
Beitrag von Lars1998 »
Hello, I have two of the 12mm Carbs from you. If i installere Booth of Them to ny quickly the one carb need a 66 jet and needle in the 4. Notch, if i install the other one it need a 66 jet needle in 2. Notch, Is that normal that even though it is the same carb it need different needle adjustment to make the quickly run best? And is it ok to drive With the needle in the 4. Notch? Just a little confused why the two same carbs need different tuning on the same bike? Is it something to do with the production of the carbs or What? Mayer you Can tell me if it is normal :) best regards Lars.
Lars1998
Re: Vergasser Nadel
The two carbs are from krippl the one that cost 89 euro
Re: Vergasser Nadel
Hallo Lars
Es ist ganz normal , dass die Vergaser unterschiedliche Haupt-Düsen und unterschiedliche Nadel-Stellungen brauchen , da die Abstimmung für jeden Motor unterschiedlich ist . Die Bestückung mit Haupt-Düsen und die angegebenen Nadel-Stellungen der Vergaser sind nur "Richtwerte" und müssen individuell für jeden Motor ermittelt werden
LG.Hartwig
Lars1998
Re: Vergasser Nadel
It is the same engine just two different carbs from krippl that needs different tuning? Is that also normal?
