Spark cap ohm
Lars1998
Spark cap ohm
Beitrag von Lars1998 »
Hello how many ohm is there supposed to be in the spark cap? Is there supposed to be used a spark cap with 1k ohm or one with 5k ohm????
SD516
Re: Spark cap ohm
Beitrag von SD516 »
When the Quickly was built there was no resistor in the spark cap.
Later resistors were taken against radio interference.
Your Quickly will run with 0, 1 and 5 kOhm. It doesn´t matter.
Lars1998
Re: Spark cap ohm
So the spark wont be better with 1k ohm instead of 5k ohm or how does it work?
Right now it have a ngk cap with 5k ohm but would Line to change that to 1k ohm but dont want to destroy my ignition coil or something because of less resistance:)
SD516
Re: Spark cap ohm
Beitrag von SD516 »
Don´t think in DC, the spark is like AC with short times and high voltage.
There are not the same rules.
Try it and smile. ;)
Lars1998
Re: Spark cap ohm
So the wuickly would drive fine with 1k ohm spark cap? And nothing would happen, i really sont understand what the higher ohm is for in the spark cap then???
SD516
Re: Spark cap ohm
Beitrag von SD516 »
There is High Voltage and minimal Current.
So there is an insignificant loss in the resistor.
This is physiks. Please try it.
Lars1998
Re: Spark cap ohm
I still dont get it, what would be the good thing about runnning 1ohm instead of 5ohm caps? Or what is the right thing to run with.
SD516
Re: Spark cap ohm
Beitrag von SD516 »
5KOhm is better für radio interference suppression than 1kOhm
but at 5kOhm the ignition energy is good enough for the combustion.
