I can see oil dripping from the outside of the clutch mechanism
What is involved for this repair?
Does the motor need to be split and pulled apart or can a seal be renewed externally?
Many thanks
Leaking oil at clutch mechanism
Re: Leaking oil at clutch mechanism
Hello Mailmarcel.
To replace the defective o-ring of the clutch cup , only the left half of the housing has to be removed , so you don't need to disassemble the entire engine .
- Neu
Danke schoen
